PRICE DROP
B.B. Ford 460 (+ 0.030” overbore) street /strip motor
Best parts used throughout. Spare parts and engine stand included in the price including flexplate, new gaskets, carb spacer, second fuel regulator, fan, rubber hose etc.
Built for a project but never used. Motor built to Ford specs./torque settings with numerous new parts. Has not been run. Valve covers and carb. are removable for inspection.
New Fel-Pro gaskets throughout. New Clevite 77 shells used throughout.
Cast iron block, stamped D1VE (1968-70) Cleaned prepped, overbored 0.030” – shells P+30, M+20, R+20. All new Rollmaster double row timing chain, new Fluidamper balancer, new pistons, new rings, new rod bolts, new shells etc. Sump is a baffled Milodon item with matching oil pump and pickup with extension to rear of sump.
Cast iron heads, stamped D3VE-AA (1972-74). Combustion chambers have had all casting marks removed, polished and evened for size. Intake and exhaust ports matched to gaskets and mildly ported. ARP 12 point head bolts, Milodon roller rockers. Valves new. Hydraulic cam (0.570/0.570), lifters and pushrods all new. Valvetrain has liberal coating of CV Grease (Molybdenum Sulphide) ready for successful startup. Headbolts, crank bolt etc. have copper anti-sieze on them, pistons and rings are liberally oiled.
Engine has a serpentine belt system with Ford Motorsport Racing underdrive pulleys, high output 429CJ water pump, remote oil filter with take-off, AN10 Stratoflex braided lines and AN10 Stratoflex (aircraft quality) fittings.
Edelbrock intake Performer RPM, 2” spacer, handmade 6082 transition plate and a rebuilt, cleaned and refurbished Holley 850cfm carb, braided lines and Holley fuel regulator. Air cleaner and rocker covers are gold Moroso items.
Extensive parts list, photographs of engine and photographs of rebuild at each stage available by emailing: chrispilling@tiscali.co.uk
Open to sensible offers as I need the space for existing drag car.
£3750 O.B.O. Keith, Chester. Tel: 01244 321624 evenings. Buyer collects.
I have additional parts for sale – see below.
Parts for sale
Ford 429/460 engine block Water plug Kit P/N 830012, new, still in packet £5.00 +P&P
Ford 429/460 Clevite 77 Bearings CB-818 P-20 (8 pairs of rod shells) new, boxed unused £35.00 +P&P
Ford 429/460 Clevite 77 Bearings MS-1039 P-20 (Full set main bearings) new, boxed unused £30.00 +P&P
Ford 429/460 Clevite 77 Bearings SH-1111S (Full set cam bearings) new, boxed unused £20.00 +P&P
Mallory Tachometer P/N TC 0807, black face, white letters, orange needle, 4.5" dia., mounting bracket
£40.00 +P&P
Autometer Fuel Gauge P/N 3411, used, great condition, 0-15psi, 2 5/8” diameter, black face, silver housing, black mounting bracket/pod £25.00 +P&P
B.B Chevy zoomie headers by Dan Olson Racing Products, 17” centre line length, reasonable condition chrome, all welds clean and solid, pipes have no cracks or breaks £50+P&P
Open to sensible offers. Combined postage on multiple purchases.
Parts for sale
£40.00 +P&P
ENGINE 1.jpg (253.54 KiB) Viewed 16124 times
ENGINE 2.jpg (289.11 KiB) Viewed 16124 times
ENGINE 3.jpg (278.88 KiB) Viewed 16124 times
ENGINE 4.jpg (259.39 KiB) Viewed 16124 times
ENGINE 5.jpg (266.78 KiB) Viewed 16124 times
